I have an 88 alfa 33 the battery light has been coming on a lot of late.The wierd thing is when i start the beast the battery light stays on and will not start,i hav eto rev the engine to get to start,and while driving the more a rev the brighter the light.I have to update the alternator to a higher amps,will fix the problem as well.
Could it be just a bad connection?
Tried to start it this morning ,would not start,did not take long to flatten the battery.Recharged the battery,still no start.Iremoved the new coil i had fitted 4 weeks ago and placed the old one back on (the 1 I took off because of the starting problems and the new 1 fixed the problem)and the car started first go idle fine stops clean(does not keep which it did with old coil in the first place)So I'm open to ideas what is wrong????::confused:
