1 - 16 of 16 Posts
Downloadable 164 Maintenance Guides in pdf format:
00 Complete Car
164S buying guide https://www.alfabb.com/bb/forums/attachments/164-168-1991-1995/890938d1446225126-my-take-buying-164s-alfa-romeo-164s-buyers-guide-ver-2.pdf
parts manuals 164 12v/24v/series4 spider"\: https://www.alfabb.com/bb/forums/164-168-1991-1995/207583-alfa-164-spider-parts-catalogs.html
01 Engine
03 Valve Gear Systems
Cam Timing Template V6 12v engine https://www.alfabb.com/bb/forums/attachments/164-168-1991-1995/66906d1179330802-cam-timing-cam-timing.pdf Cam timing pdf template. Print it off on 8 1/2 x14 paper at 100% scale setting. This is Rick's Template he posted for us to use.
Guide to 164 12v Timing Belt Tensioners.pdf https://www.alfabb.com/bb/forums/164-168-1991-1995/446465-guide-164-timing-belt-tensioners.html
Checking cam timing on 12v V6 engine in car: Checking Alfa 164 12v V6 engine cam timing.
https://www.alfabb.com/bb/forums/164-168-1991-1995/282681-checking-alfa-164-12v-v6-engine-cam-timing.html
04 Fuel Air and Exhaust Systems
John excellent fuel pump change guide: https://www.alfabb.com/bb/forums/164-168-1991-1995/665262-alfa-romeo-164-tank-fuel-pump-repair-refurbishment.html
Chassy's refurbishing 164 fuel sender unit: https://www.alfabb.com/bb/forums/164-168-1991-1995/615033-fuel-level-sender-repair-cleaning.html
164 Fuel Hose Replacement Process from engine compartment to fuel filter areas:
https://www.alfabb.com/bb/forums/attachments/164-168-1991-1995/867553d1442892735-164-firewall-fuel-hose-replacement-164-firewall-fuel-hose-replacement.pdf
Motronic ML4.1 91-93 12v V6 wiring diagram: https://www.alfabb.com/bb/forums/attachments/164-168-1991-1995/851785d1440549851-electrical-systems-components-posters-12v-motronic-wiring.pdf
Motronic Testing diagnostics 91-93 12v V6: https://www.alfabb.com/bb/forums/5344273-post3.html
Idle fault diagnostics https://www.alfabb.com/bb/forums/164-168-1991-1995/206282-diagnosis-idle-faults-164-a.html
05 Engine Electrical Units
Starter NO crank troubleshooting
https://www.hagerty.com/articles-videos/Articles/2017/08/08/testing-a-starter-motor?utm_source=MagnetMail&utm_medium=email&[email protected]&utm_content=17-Hagerty Weekly News 08-23&utm_campaign=The VW Bus is back, Monterey auction shockers and recap, and the surprise legacy of the Mustang II
06 Lubrication System
07 Cooling System
12 Clutch
13 Transmission
164 Reaction Rod (Shifter) Bushing Replacement Guide.pdf
16 A/T
21 Suspensions
22 Brakes brake line replacement info https://www.alfabb.com/bb/forums/8401632-post17.html
https://www.alfabb.com/bb/forums/attachments/164-168-1991-1995/1561828d1555606320-brake-hard-line-rub-leak-alfa-romeo-164-brake-line-replacement.pdf
40/43 Electrical Systems/Onboard Electronics
45 Air Bag https://www.alfabb.com/bb/forums/7586162-post329.html
91-93 AR164S (164B/L nearly identical) https://www.alfabb.com/bb/forums/attachments/164-168-1991-1995/843337d1439249783-electrical-systems-components-posters-164s-91-chassis-electric-upper-left.pdf
164 Dashboard Non-Annotated https://www.alfabb.com/bb/forums/attachments/164-168-1991-1995/850033d1440214224-electrical-systems-components-posters-164-dashboard-wiring-connectors-upper-left-ver-2.pdf
164 Dashboard Annotated Ver 2a w-insert.pdf https://www.alfabb.com/bb/forums/attachments/164-168-1991-1995/851161d1440443374-electrical-systems-components-posters-164-dashboard-annotated-ver-2a-w-insert.pdf
164 Electrical-systems-components https://www.alfabb.com/bb/forums/attachments/164-168-1991-1995/850049d1440217399-electrical-systems-components-posters-164-electronic-components-upper-left-ver-2.pdf
49 Body
How to remove front seat headrests: https://www.alfabb.com/bb/forums/7040250-post8.html
Frame Alignment chart https://www.alfabb.com/bb/forums/attachments/164-168-1991-1995/277720d1366237409-alfa-164-alfisto-steves-maintenance-tips-alfa-164-frame-chart.pdf
80 Heating and Air Conditioning
https://www.alfabb.com/bb/forums/164-168-1991-1995/379737-164-stepper-motor-assembly-refurbishment.html
164 Coolant Temperature Gauge Correction https://www.alfabb.com/bb/forums/164-168-1991-1995/341594-164-coolant-temperature-gauge-correction.html
164S Oil Pressure Gauge & Sunpro Sending Unit https://www.alfabb.com/bb/forums/164-168-1991-1995/198632-164s-oil-pressure-gauge-sunpro-sending-unit.html
R-134a Conversion Guide https://www.alfabb.com/bb/forums/164-168-1991-1995/198765-r-134a-conversion-guide.html
Colder air mod POA valve removal https://www.alfabb.com/bb/forums/164-168-1991-1995/685132-164-c-conversion-colder-air-mod.html#post8455804
Cruise Control Troubleshooting https://www.alfabb.com/bb/forums/164-168-1991-1995/197614-cruise-control-troubleshooting.html
164 12v Instrument Cluster/Center Vent Removal https://www.alfabb.com/bb/forums/164-168-1991-1995/446145-164-12v-instrument-cluster-center-vent-removal.html
Steve
RE:164 12v camshaft removal
Is the 22mm cam sprocket nut a left hand or right hand thread please?
Regards
Axelhex
Steve
Regards
Axelhex
Lefty-Loosey left hand threads. You need special tool to fit holes in cam pulleys to hold pulleys for both loosening and torquing 22 mm nut. You also need special puller to pop hub off cam end taper.
Added some more of Roadtrip John's maintenance guides to first post of this thread.
Good morning friends .... just bought a legitimate alfa romeo 164 q4 ... beautiful white with 56,000 kilometers ... a rare gem ... only have a few details that left me hair stand on end ... I wonder where I tidy the catalog parts of this car ... such as ... the need rubber hose liha MAF to BITs and the need 3 cups of the fuel tank ... where 1 go fuel pump and the other will the valve canister and the last will displacer ....
if someone help me would greatly appreciate it ... because here ni Brazil ... I'm the one who got this relic ...
I added TSB for 91-93 air bag reset code procedure to first post under code 45.
Discussion Starter #12
Discussion Starter #13
Discussion Starter #14
Gentlemen -
The owner's of the BB, in addition to the rest of the inane changes they have made, they have also locked me out of editing past posts. Therefor, I cannot update, revise, or delete any technical guides or advice, including the Supplier's List. I no longer control my own content. Yet another reason I am leaving the ALFABB. It is truly pathetic that after the past 16 years, it has come to this, but that's the reality.
Discussion Starter #16
1 - 16 of 16 Posts
