'92 164 trying to remove front door trim.
dismantled front finisher infront of door handle it slides out, then the 2 armrest screws, 3rd behind door handle itself, 5 lower screws for door pocket, pulled from clips, so far all good. removed all other visible trim and hidden screw under upholstry material on upper half, and the air duct screw.
CAN'T figure out how to dismantle armrest top point! (door pull) I tried peeling off gently the finisher stripe on back side, but it just seems glued on and not a cover for anything. only thing obvious is door pull screwed somehow on top of the door trim upper half with no visible access...
Help?
Help?
