My rear left door lock actuator seems to be stuck, the door is locked and i can't even unlock it manually by pulling the pin up since it won't come up. does anybody know if there is a way to get the door open. :confused:
If no other tricks work ... then there's always the last resort to take the inside door panel off and get your hand in there to work the door lock and linkage mechanism!
The problem is i can't open the door it's stuck closed, would i still be able to take the panel off? If i'm not wrong there should be some screws at the bottom that need to be taken off, and i can't get to it.
Didn't say it will be easy ... that's why I said "the last resort" ...
Don't remember the exact details (without going to take a closer look)! But you can look the door on the other side to get some idea. You might need to move the chairs (lift the rear seats if you have to) etc.
