I am working on my 61 spider and am not sure of the correct arrangement of the cables through the forward bulkhead!! As viewed from the front of the car I believe the inner-most grommet above where the hand throttle wire comes through, there should be the choke, and the washer bag tubbing. Not sure of which goes first.
Moving toward the fender above the steering column the next should be the oil press hard pipe, the speedo cable and then the tach cable!! Not sure of what order?? and of course the closest to the fender would have the volt regulator and relay harness..... Does anyone know the order in which they go, starting from the center and working outwards toward the fender.
Thanks Ric
Thanks Ric
