1 - 10 of 10 Posts
1971 1750 Spider Veloce hot-rodded with Euro spec 2.0L
I am having trouble with reverse staying in gear on my ‘71 square tail. Decided to look at the mounts, they look a little saggy to me. What do you think?
Automotive tire Motor vehicle Vehicle Steering part Automotive design
Automotive tire Automotive wheel system Gas Auto part Tints and shades
I haven’t yet checked anything else that’s typically the cause in this situation other than the console, which does not seem to prevent or block shifting into reverse.
· Premium Member
I am having trouble with reverse staying in gear. Decide to look at the mounts, they look a little saggy to me. What do you think?
What year spider? THe 1985 and earlier spiders have less clearance around the console and any issues with mounts can affect the shifter.
Discussion Starter · #4 ·
Yeah, those are done. Unless you know when it was last replaced I'd assume your transmission mount needs replacement as well.
The PO had replaced the tranny not too long before 2016 when I bought it. It’s got a 2.0L swap in there but no idea how long ago that was.
Discussion Starter · #5 ·
1971. I’ve got the console off but may stop my investigation here and start with the engine mounts, then the transmission mount to see if it’ll improve the engagement.
I’m not sure how much the shifter is supposed to spring back but I can feel the reverse gear engage, then very slightly back out (perhaps due to misalignment) then the shifter moves back toward center a little. This issue was not present when I bought the car so it’s likely the mounts wearing, shifter fork, alignment, and/or boot positioning.
Aside from the motor mounts you need to brace the 1.1 hp starter to the motor mount to prevent torque from the starter from putting stress on the bellhousing starter attachment points and cracking it.
Reactions: Ragnomaniac
· Premium Member
Does this still happen with the console off? Are the shift boots causing the shifter to push it back out of reverse?
This is definitely a symptom of a sagging and/or broken transmission mount but there could be other causes
Discussion Starter · #8 ·
I’m thinking it’s the mounts. Will find out soon enough as I’m bringing it in to my mechanic tomorrow.
Going to try it with the console loose and see.
Discussion Starter · #9 · (Edited)
I left the console loose and reverse did not pop out. :) On to the mounts!
Update: It popped out under some load and after some distance but mounts will be replaced next week.
Reactions: alfaloco
· Premium Member
Well, sometimes if the gearbox has been popping out of reverse for a while due to the shifter hitting the concole or someone has a habit of riding with their hand on the shifter while in reverse, there can be some gear wear that will cause it to keep popping out and it "may" require a tear down of the gearbox. Hope that is not the case but I have seen it before.
1 - 10 of 10 Posts
