I'll you know ASAPCan you get a part number off the old cap? Might be able to cross reference it with another brand or make of car. I know Bosch made some parts the same but used different part numbers for different cars. Might find something like a Volvo or such will exchange.
ok thanks2.0 v6 CEM? Is the distributor itself different to 2.5 jetronic? If so - it could be quite hard to find one, as there were only ~2000 CEM (Alfa Romeo's own engine management system) cars made if I remember correctly. I have a 90 v6 CEM (not running though), I could look at what number I have on my distributor, if you want.
thanksSorry, for late reply. Finally got around to searching for the distributor. Found a number on it DT454A. Check your distributor base - I think it will show the same number.
A search on google shows the following crossreference numbers:
Original OE Part Numbers
BOSCH 0237322001
BOSCH 0237303001
DELCO DRD6857
DELCO DRD6855
MARELLI DT454A
MARELLI DT454A
