Painting a Transaxle case
Hi Trooper
You said
1-Can I disassemble the differential portion of the unit so I can have the external aluminum cast case for cleaning and powder coating, WITHOUT NEEDING TO RE-ADJUST BACKLASH OF CROWNWHEEL TO PINION TEETH OR OTHER ADJUSTMENTS?
The short answer is YES. The differential comes out as one piece. Take the side cover off, slide out the differential, put the side cover back on, and paint away.
The side to side placement of the differential is set by shims in the main case and side cover where the stub axles enter. As long as theses shims aren't interfered with the differential can be R&R (Removed & Reinstalled) without concern.
Now lots of people powder coat transaxle cases without any apparent problems. It makes me a little nervous. I worry the high temperature involved, that the case is going to distort slightly. Ask the powder coating guy, how hot the powder coating oven gets. If it's over 240F, I wouldn't do it.
2. Since I have the original speed ratios for a 1982 on the car and now I got a 1984 fully functional transaxle, any changes of gears (1st and 2nd maybe) to makie it more driveable for street use?
You can swap the entire set of gears and the matching layshaft from one transmission to another. However this will mean getting a new main shaft shim, and re-setting the crownwheel to pinion backlash, and dept. I'd farm this job out.
Hope this helps
Hi Trooper
Hope this helps
