Hi all,
I have been an avid reader of your suggestions and I hope you can help me with this one.
I'm trying to dismantle the layshaft. The shop manual says to mount the shaft on a vice equipped with protective jaws (I'm using a leather belt for this).
The nut at the end of the shaft (on the side of the 4th gear) is stuck and no matter how hard I close the jaws, the shaft spins when I try to undo it.
I'm also worried that the 5th gear I'm try to hold with the jaws can get damaged by the pressure.
Any suggestion on how should I do?
Thank you in advance!
Enrico
Enrico
