Disegno di bertone badge Help!!
1884 Views 3 Replies 3 Participants Last post by  alfa10530
My GT 1300 Junior is just painted!! After two years of patience it is finally coming to an end (At least the bodywork...) The problem is that the three holes to which the badge is mounted are missing. So I was wondering if someone can help me by telling me the correct position, maybe centimeters away from certain places or a close photo...
It is a 1972 model so it has the later type black badge.
Thank You.
If I remember correctly, you can access the back of the holes from the front right wheel well. You should be able to see where the bondo came through.
Regards,
Lawrence
'71 GTV
I'm pretty sure the later model badges sit in the same position as the earlier model badges. The only difference is that apparently on the pre-68 models there was one badge either side, and on the post-68 models the badge was only on one side.
Lawrence has a good suggestion, but you can take a look at this post for the positioning measurements.
The post you want is about halfway down the page.
Cheers,
-Col-
Lawrence has a good suggestion, but you can take a look at this post for the positioning measurements.......-Col-
Thank You! That is exactly what I wanted.
