21 - 22 of 22 Posts
Richard Jemison
trans
To check other shift arm positions to insure the 3/4 and 1/2 are centered, with the tail covering off remove the bolt in the R/5 fork/shift rod and engage 5th gear(without moving the rod out of it`s neutral notch). Feel for any resistance to turning the main shaft, should turn freely. Then move the other two shift rods a small distance towards each gears engagement. If a small movement loks the shaft(increases resistance) more than the same amount of movement towards it`s other gear then that fork is not centered.
Then you have to open the box, and likely replace the syncro band on that gear.
Discussion Starter #22
Richard, Thats a great guide. But replace the syncro band???
21 - 22 of 22 Posts
