Hi
I have the wrong did stick fitted. The PO complained of bad oil leaks but the dickstip tube is 12cm whereas the dipstick is designed for an 8 cm tube. So the full mark is 4 cm above what it should be. No wonder it sprayed oil.
Questions”
I have a Classic Alfa EN064 dipstick that measures 240mm from the retainer to the max fill level.
1/ is the tube removable. If so I can cut 4cm off it. If it does com3 out is it a screw fit or push fit?
2/ I cannot find correct dipstick anywhere.
I can cope with the math of deducting 4 cm from the level but the min level is below the bottom of the dipstick and am fed up with my local Italian car garage being helpful and “topping off “ the oil despite the number of times I have explained it to them.
Not a serious problem but who sells the correct dipstick because i do not seem to be able to slide the top collar down 4 cm.
thanks
Questions”
thanks
