Procedure is exact same for both.
1991 Spider Veloce, simple steps.
Setup is quite inviting. Filler/level plug located just bellow half height on both units and of course drain at the bottom. No obstructions in the way. No need to remove any other components.
- Place your new oil outside in the sun. (It will be easier to push later)
- Take the car for a short spin to warm up the transmission and differential and lift the residue. I suggest you drive to home depot or the hardware store of your choice and get some clear tubing. ¼ ID is good enough.
- Lift the car in such way that the unit you will work on will be in level position. That is important!
- Open the top plug first. No need to remove it at this point.
- Place a small oil catch under the drain.
- Open the drain plug. You should be able to turn and remove the plug by hand once loose.
- Go, have a coffee or a beverage of your choice. You have 15 to 20min to relax. We need to make sure that all the old oil has the chance to drain out.
- Clean the plugs and put on the new copper washers. If by any chance you don’t have the new washers, you may try and flip the original. Not recommended though.
- Fill the unit with oil. (The easy way)
- Remove the cup from the oil bottle
- Drill 2 holes in it. (I used ¼ bit)
- Insert about a foot (enough to reach the bottom) of tubing trough the cup and leave about two feet on the outside.
- Insert a shorter piece, (few inches long) in the second hole.
- Connect your air line to the short side and place your longer tube in the filler port on the transmission or differential.
- Open the air valve and watch the oil flow up. 5-10 PSI is adequate for the job.
- Close the air supply once the oil starts to flow back out of the hole.
- remove the tubing and wait a minute or two so the oil stops dripping.
- Close the plug and wipe it all clean.
