21 - 27 of 27 Posts
Would it be possible to use the crankshaft from a 1750 105 engine in the 116 1.8 engine and then use the flywheel etc from the 105?
Would this cause any problems ?
The 105 flywheel should have 8 holes while the 116 crank could already have the 6 hole version. Check that first.
I am aware we have to modify the crank to 8 pins as well as for the bearing. I will be balanced as well while its out. From what I understand I still need to find a 115 oil pan and oil pump.
You can't modify the 6 hole crank to 8 holes.
Thank you. After 15yrs in the aircooled VW world I still have a lot to learn about my Duetto. Is the item from Alfaholics the correct one for mounting a 6 pin crank to the 115 bell housing?
1608480
It's not the question about the bell housing. If you have a crankshaft with 8 holes you need a flywheel w/8 holes. You've asked for fitting a 1750/105 CS which should have 8 holes. Did you check how many mounting holes your CS you want to fit really has?
Good evening and please forgive the newbee questions. The new engine has 6 pins. I found an oil pan and pump. What else do I need to consider to mount the nee engine in my S4?
If crank is coming from an 116, you need to check depth of pilot bearing bore in the crank/rear boss. Some 116 cranks need to be modified to take a 105/115 pilot bearing.
21 - 27 of 27 Posts
