1 - 1 of 1 Posts
Hello, after stripping and cleaning my pair of dhla40 carbs, when checking the aceleration pump, on one carb, one of the jets doesn't squirt the has the other... I've opened the pump circuit again, blowed air through it and it stayed the same. Changed the injectors betwen sides, and the problem remained in the same side... Should i strip everything apart again and have ultra-sound cleaning to the main body? Or do you think that having just one of the four injectors squirting a bit less is ok?
Thanks for any advice!
I'll make another post on setting the fuel pump volume output...
1 - 1 of 1 Posts
