1 - 9 of 9 Posts
I have posted this once before and got a good responce but no action... I need to find a keyless entry remote (or 2) for my 92 164 would love to beable to use alarm. Also would need programing instructions. If anyone has a couple or just 1 please let me know what you would like for it..:cool:
Very hard to find a remote that will work with your car without opening the remote up and soldering some spots as I have herd. I do have the remotes as well if you want to go that route.
Alfa 164 91-93 alarm remote coding
wow ok i will keep this in mind a little more than what i was wanting to spend i really just need the remote but will definetly consider it...
Not that easy but if you do find a remote and you don't have your old one you first need to find RF code sticker inside ECU so you can change code in new remote with a soldering gun.
If you have working remote you can buy aftermarket remotes that are designed to lay along side old remote and pick up code but most people don't have old working remote.
The 94-95 systems are completely different so don't get a remote for that model it won't work on your 91-93.
See this TSB for how to solder in codes: Alfa 164 TSB 40.95.02
And you thought it was a simple plug and play exercise didn't you!
I do have my fob, altough held together by rubber bands it does work. where can I find the aftermarket fob that rf sense ? i would love to buy 1 or 2 new ones. Robb
Search eBay for examples of them.
A couple of years ago Michelle at Spruell had some on the shelf that were new. She wouldn't guarantee them because of the age of the batteries.(corrosion and all) You might give them a call and see what they have still.
Paul
Need a keyfob for my 94 LS
My '94 LS didn't come with a keyfob for the keyless entry. So I'm in the same boat as several others. I guess that I'll try to fina an Alfa fob, but I'll probably end up getting an aftermarket unit.
1 - 9 of 9 Posts
