Stickers
1- Tune-up/emission data sticker on inner right fender
2- Lubrication sticker under the hood panel, towards the right
3- Spark plug sticker (saying to use 2HL Lodges instead of HL if you want to blast the speed limits without holing pistons
) underneath #2
4- Fispa air filter sticker on air box
5- Tire pressure sticker inside glove box door
6- Breaking-in recommendations on a sleeve wrapped around the driver's sun visor
7- Paint code sticker inside trunk lid, towards the right on the structure of the lid
8- "Alfa Romeo 2000 ... fuel injection" large display sticker at base of rear windo, towards the outside
9- "This seat must not be occupied when car is driven" sticker in the middle rear backrest (GTV was sold as a 2 seater in USA, not being fitted with rear seat belts)
10- Ate blue fluid sticker on brake booster (yes, these cars were supplied with blue fluid)
11- Marelli sticker on coil
12- DOT approval plate (embossed plastic with serial number and build date) on the driver's side door jamb
13- Metallic model number plate (115.01) riveted to the firewall
14- A/C cars had a green background "aria condizionata" sticker in one of the windows
Some are available as reproductions (see other threads on this site) but I've never seen items 6, 8 or 9 anywhere.
European market cars didn't have items 1, 3, 8, 9 and 12.
The air filter sticker on carburated cars didn't exist, the information was silk-screened in yellow on the air box.
On item 13, the model number for the European 2000 GTV is 105.21 or 105.22 if RHD.
Here is what was found on a brand new, US market 2000 GTV Alfa between 1972 and 1975:
