Hi Ulf and all,
After having deleted a part of my post #7 , here a, in some more conditional mode rephrased, theory from the statement that I wrote in the first place about what could have happened with the 750 Veloce inlet manifold.
Please understand that it is only a theory that still needs confirmation or disapproval . Maybe other testimonies or not published official documents are to be found and could hopefully be decisive in this matter.
My only purpose for making this statement now yet in this recent thread, is for trying to find for now, a kind of coherent and plausible answer about why there were different 750 Veloce inlet manifolds as fortunately showed here by Ulf.
If at the end it would turn out that there would be a kind of definitive indication, a sort of “ Stone of Rosetta “ showing up here, that would prove that this theory is correct or even is wrong, then I would be more than happy.
The abovementioned argument to stay prudent in this matter is important as I can’t prove the correctness of that theory by official Alfa documents , it is only a coctail from official catalog data combined with memories that I have from discussions that were held, discussions that I can’t retrace anymore, … a little dangerous, I know .
All starts with my understanding that there were former discussions held about the brand of the startmotor that was used on the 750 Veloces.
Finally, as listed in the catalogs btw, Alfa went for the Marelli as the one starter to be used on the Veloce 750 cars .
Why ?
Besides the fact that Alfa and Magneti Marelli were both Italian companies of course, this would have something to do with the Veloce being negative grounded, but maybe also with the position of the solenoid ( and so the connectors) that was more oriented downwards than the solenoid on the Lucas starter. This difference can be noticed on the next pictures from an engine with Marelli and an engine with Lucas .
Was the lower position of the connectors, and so the Marelli starter, chosen for these safety reasons: preventing the connectors from touching acidentally the horizontal rod between the acccelerator pedal lever and the bellcrank ? To my knowledge, we don’t know that from official documents.
But what I would remember from all this is that there could have been a problem with that rod, getting to close to the starter connectors.
The presumption I make now is that Alfa would have altered therefore the position of that rod to avoid accidents with that rod causing fire. The higher position of the bellcrank is perfectly noticeable on the picture in post # 1 … We know from the catalog that Alfa indeed changed the accelerator pedal lever, the bellcrank shape and the length of some of the rods. Why would they have done that if not for changing the position of that horizontal rod ? … any thoughts ?
Hence my second assumption here that Alfa changed at this occasion, and for the same reason, also the chape of the inlet manifold, bringing the bellcrank pin higher and improving that way also the traject of the rod.
Admitted, I don’t know of any evidence coming from Alfa for this up to now. Anyone ?
But the fact is that there were two different manifolds, having different bellcrank pin heights.
If this all would be correct, then Alfa ‘forgot’ to mention an altered manifold number and a new picture in the catalog.
As far as I know, the earliest parts catalog showing Veloce parts is the 11/1957 catalog 608. The picture of the manifold in there shows the manifold with the longer casting part underneath as Greig mentioned before, the same as the left manifold on Ulf’s picture in post # 1, probably making that one the earliest manifold.
Important to be noticed is that the changed rod ensemble was already listed in that early catalog, so it was already applicable earlier than 11/1957. But when ?
Unfortunately the catalog doesn’t mention when exactly the change of the rod (and maybe the manifold ) occured. If nobody shows up with new material, we only can rely on testimonies of early Veloce car owners I guess.
Once more, please don’t take the theory for granted, the last thing that I want to create is a story that, if it is repeated often enough, would be accepted as the real truth like this happened already before at other occasions. So it is only meant as a kind of first move to try to find out what happened in 1956, and for what reason.
Therefore thank you for all additional input about this matter.
Rgds,
Thierry
