The reason I am adding another light is to see better at night.
I thought the purpose was to create a day time running light?!?
If you're thinking of using it at night and setting it to splay light onto the ground more or less right in front of the car you're making a very grave mistake.
While it will indeed light the hell out of the road 10~20 feet in front of you, it'll also effectively 'blind' you to distances further out in front of the car as your eyes will want to focus on the easiest thing to see.
IOW, you will (not 'may', not 'possibly', not 'could', but
will) end up looking 15 feet in front of you where the light cone on the ground is brightest and never seeing that deer/kid/cow/horse/parked car or whatever 50~100 feet out until its far too late. Well, you could see it if you were looking and straining to focus on some dim something out there around the glare of the close aimed light but you won't be because the brighter light ring in front will be attracting a huge portion of your eyes attention most all the time and your brain will go into drone mode making for greater and greater time lapses between attempts to see what you won't be able to see even if you're looking until you start to simply faze out and don't see potential dangers until a millionth of a second before impact.
Well, that and an excess of light nearby causes your eyes to start to shift from night vision mode to day vision mode, so you lose even more perception of things out in the darker areas.
Now if you aim an auxillary light in such a way that it doesn't flood the area directly in front of the car, you'll prolly end up with it blinding the crap out of oncoming traffic or annoying some cop just looking for an excuse.
If they stop you, you're almost assured to get the 'improper use of fog or offroad lights' ticket regardless of the aux light being a fog light or not.
If you'd have said right off that you intended to use it at night to enhance vision, likely replies would have been geared more toward 'no don't do it' or 'just make sure your existing lights are in good order and properly aimed'.
