Ok guys apologies but as I have no reference point here to assembly...how do these parts fit back together? I get the connection between the spring steel clamp and the plastic hose attachment but is this supposed to be sandwiched somehow between the dash opening? Also, does the circular plastic top vent just sit in the dash hole???? If so what's the radial spring wire for on the underside? Any info would be appreciated. Thx S
From my experience, you push the ring down in to holes in the dash. You push the vent down on to the ring, which should secure in place with the clips. You then drop the vent grill on top and try to get those wires to fit in those slots on the vent. If you don't/can't get the wires in place (or the wires are damaged, like one of mine) then the vents will have the tendency to spin wildy and fly out of the dash like a frisbee at high air flow
