Hi All,
Having a problem with my sud. I've just renewed all of the suspension (it's got 33 setup). When bringing the car home, going left round a corner, the car lost drive. Had a look and the outer cv had become separated (the splined end has popped out of the joint). Took complete driveshaft off and had outer joint replaced at a cv place. Driving the other day and the same Thing has happened, again when making a left turn. Will be taking shaft back to be fixed again, but I don't want the same thing to keep happening. Any ideas what could be causing it to keep popping out? Car is lowered about 30 or 40 mm on h&r springs and koni yellows, superpro bushes all round, there is some negative camber but I've had the car lower in the past without any such problems. Any ideas?
Cheers
Cheers
