Dear Community,
first of all, thank you for letting me join the forum. I’m already reading it for years and it helped me several times. I appreciate that experts take their time to explain problems in detail, in a friendly manner. I hope that you can help me with the following question.
Currently I’m converting and tuning a 2000 Alfetta engine for my GT Junior 1300, from ’73. In the coming weeks I would like to make the custom works to couple the crankshaft, flywheel with the rest of the drivetrain. Currently my car has a hydraulic clutch (I’m not sure if it is original for the year of production). Because it is hard to get a 2000 flywheel, with 6 holes, I’ve decided to turn it. For this, I have received a 1600 flywheel as a sample (but I don’t know if it is for a mechanical or a hydraulic clutch). The plan is to “copy the geometry” of the 1600 clutch, but adding only 6 holes for the bolts of the crankshaft and to press the gear ring from the Alfetta flywheel on the new one. This way, I can have a lightened, custom flywheel. I have also read that there might be some issues also with the trust bearing and I might need an adapter. My questions are the following:
- How do I identify my current 1600 flywheel if it is for mechanical or for hydraulic clutch? (the friction area has an inner diameter of approx. 138,5 mm and an outer diameter of 223 mm, it has 8 holes)
- How do I know if it will work with my current 1300, hydraulic clutch – gearbox bell combination?
- Is it possible that my hydraulic clutch is original?
- Is there a way to identify my gearbox and 5th gear ratio, beside of measuring it, like part numbers, casting properties, etc.
- I have observed 3 additional holes on 1600 flywheel, at the inner edge of the friction area (photo attached). What is the purpose of these?
- If the 1600 flywheel is for a hydraulic version, can I use it as a sample and fabricate my 2000 flywheel? Is it afterwards compatible with the clutch set?
- Do I need a thrust bearing conversion? When is it needed and why?
- Is there another flywheel, maybe from a newer car (155, 164 for instance), which I can take for this project?
- If you generally have some comments on, for example the details which I have to consider or any ideas, I would appreciate them as well
I’m looking forward to hear from you.
Best Regards,
Marcell
Best Regards,
Marcell
