Hi,
If someone has a 164 cruise control stalk collar lying around
could you do me a favour and measure it for me?
Just the arrowed bit here -
I need the overall diameter, thickness and recess depth ( I appreciate that that is not going to happen if it is fitted to the car! ) and if a radius gauge is available ( that's a bit of a long shot I know! ) the radius of the outer edge. The primary measurements I need though are the overall diameter and thickness.
Reason? I want to fit cruise control to my 1997 GTV ( which was never even an option on the car throughout its production history ) and as with everything I do to my car I want it to look as if it was put there by the factory. As the wipers/lights control stalks are essentially identical to those in the 164, the 164 cruise stalk is the obvious choice to me. To that end, I have purchased the Rostra 250-3304 which appears to be the same as the 164 cruise stalk
http://www.rostra.com/images/2503304/2503304-small.jpg
To make my installation look more 'factory' I want to make a replica of the 164 collar to finish it off neatly.
Thanks.
Moderator
1991 164L
Looks like you have the collar already on the stalk or is that just a picture of somebody elses?
It's just a picture I've saved whilst thinking about this - but I cannot remember where from. It'll be taken down as soon as I have an answer as it is not mine.
I did mean to add that in my original post.
Moderator
1991 164L
Looks like the part number of it is 60557835.
Discussion Starter · #5 ·
I think that is the washer that goes under the fastening nut inside the cowl. You can sort of see the collar on the stalk in the parts diagram.
FIAT ePER
Discussion Starter · #7 ·
That's fantastic, thank you very much.
I have a lump of aluminium bar which should be arriving Monday. So I'll be sticking that in the lathe soon after.
Again, many thanks.
