Moderator
Yes, no and maybe.
24v crank shaft 96412842 replaces 96412092 replaces 96412068, etc but you have to check pitch of flywheel bolts earlier cranks had 12mx1.5 later ones 12mmx1.25. Also maybe 96412831, 60816414 and 60753003.
Even Alfa 75 3.0 used same crank but again check flywheel bolts
Moderator
Assuming the bolt pattern is the same, you just need different bolts then, I take it?
Yes, bolt pattern the same but bolts come in different lengths as ePer DVD lists three different lengths for latest (First one I listed with fine threads) crankshaft number depending on whether for A/T or 5-speed or Model 75.
