1 - 9 of 9 Posts
Quick question:
My caliper doesnt fit inside of my crank pulley so I cant figure out what size the nut is. I need to go and buy a socket to turn this pulley. Could someone tell me what size socket to buy?
James
Thanks guys, I picked up a 1 5/8. 41mm wasnt to be found.
Now it is time to get on with pulling the driveshaft (my first time)...
Pulleys are different but crank shaft nuts take same sized socket.
Jes
Figured :p BTW, I came across the spacer for the 164 starter if you need it - free.
Jes
If anyone cares to know the thread on the crankshaft nut is a 28mm x 1.5 pitch. Had to make a tool to attach a degree wheel. Jesus that nut is tight! Book says 175 foot pounds, I swear we put 250 plus to get it to break loose.
greg
1 - 9 of 9 Posts
