I've been done to Autozone 4 times already, tried 28mm too small 29mm (The biggest they had in metric-too small, but not by much), 1 1/4" and (too big, maybe because of the outer diameter of the socket, not sure) 1 3/16" (too small).
If my recollection is correct...36mm.
If you have that socket size, could you verify for me as I'll have to go to napa to get correct size since Autozone only has 29mm-These trips back and fro are more of a hassle than actually getting the thing off.
I did a search...try searching "socket size for front crank bolt" using the search feature (as I cannot figure out how to attach the link here).
Good luck.
