You don't say where the crack is, but if a serious or complicated weld, I would probably swap everything on/in to another block. Should be able to find a 2l block at little or no cost.
You don't say where the crack is, but if a serious or complicated weld, I would probably swap everything on/in to another block. Should be able to find a 2l block at little or no cost.Okay I made a post earlier that I had a coolant leak, but now after close inspection I have found out that there is a crack in my block.
The car is a 76 spider and I have done a lot of work to it, so I would hate to let it go. What are my options? I have way more hours than money in the car, and I am attached to it.
What would you do if you were in my position?
........excellent prep advice,If you use sealant, you will have a very difficult time welding due to imputities.
However it can be ground out....
I suggest cdraining the coolant and blowing the coolent out then cleaning with Carb cleaner. Thend sand an area about 1/2 inch larger than the crack to have an unpoluted block surface. Mix JB weld and cover crack. Drive the JB weld into the crack with a flat hammer or such to force the JB weld into the opening. Then coat over the crack with about 1/8 thich puddle. Let sit for about 4 days to totally cure. Then fill and drive.
