With the car in 5th gear, 185/70R14 tires and a 4.11:1 rear end, your RPM should have been: 3594.900684123614
With the car in 5th gear, 185/70R14 tires and a 4.11:1 rear end, your RPM should have been: 3594.900684123614Sorry for such a banal question but can anybody out there who has a stock S4 Spider please tell me approx what RPM you are showing at 80mph? I used the very good thread (on this forum) to adjust my Tacho and just want to make sure it is close. At 80mph I am now showing 4100 rpm. Is that about what it should be?
PPS-to everyone with all the advice thanks you VERY much. I managed to fix the VVT issue and the entire flat spot issue on my S4. The low idle was in fact (I believe) an incorrect reading tacho!
If he has the those tires, they are a little smaller in diameter and 80mph would put his car at 3609.7556456282577RPMNot sure if it adds to a significant difference, but if the S4 has the phonedial alloys, the stock size is 195/60 x 15. The starfish Campys are 185/70 x 14 if the S4 was not a Veloce model.
Seems that your numbers would be affected a few zillionths by tire wear.If he has the those tires, they are a little smaller in diameter and 80mph would put his car at 3609.7556456282577RPM
It's not me, wish I could think of numbers just like that, that was the calculator, cut and paste.DDDouglas, if you could be more precise
Thanks man, this is great
