Coming out of the other side on a head gasket R&R of my 84 spider. Having flushed the cooling system for the third time I can nearly recite the fill and bleed steps by heart. My question surrounds coolant capacity. I don't think I have never drained 2.5 gallons as I never measured, even though I open both the radiator drain and the rear left side block drain. (Heater set to hot)
I do know I have not put in over 2 gallons because I'm using new containers that are a gallon each. The second is almost 1/2 full and I haven't opened the third. With water having come out of the pump bleeder and then intake bleeder, how do you get the rest of the coolant in?
Even at tstat opening temps, the level is not dropping in the rad enough to take any more coolant.
