Dear Alfisti,
Just thought I would share with you my latest battle with my 1976 (Series II) Alfa Spider 2000's electrics. On several occasions during this winter of long cold nights I had attempted to switch from MAIN beam to DIPPED beam only to somehow end with NO beam! The headlamps would switch off completely and only be restored by frantic wiggling of the headlight stalk.
This was, I thought, a trifle inconvenient. My wife, a passenger on one of these occasions, put it rather more strongly as we hurtled blindly through the pitch darkness …
So what was going on?
Well it quickly became evident that it was a bad connection somewhere inside the control column mounted switch that controls the side lights, headlights and indicators.
I suppose I could have tried squirting stuff inside the switch, but I just thought this was too important to not fix properly so I decided to remove the switch and refurbish it. To this end I figured I needed to remove the steering wheel. Well, as many threads on this forum testify, this is not necessarily as simple as it may appear. I tried, with a variety of pullers and hardened bolts, and failed utterly and miserably to shift the wheel.
So then I asked myself, could I get the switch out with the steering wheel still in place?
And the answer is YES!
If you are faced with a similar problem and want to know how I did this then please read on ...
Removal - Step One
Take the instrument shrouds off the speedometer and rev counter. This allows better access and more light to reach your target area of work. A small self tapper needs to be loosened at their base and then they pitch forwards and off. They are probably identical but I am paranoid so store them separately to maintain L and R.
Removal - Step Two
Disconnect the battery. You will be waving all sorts of metal tools near the fusebox so this seems like a prudent act.
Removal - Step Three
Remove the upper and lower plastic covers from the steering column. They are held on by four or five bolts into the lower shroud, and you will need a small metric allen key to undo them, as well as a flexible spine! The lower one falls off easily; the upper one needs to be withdrawn carefully and can be a bit of a struggle. Fortunately plastic bends a bit. This exposes the headlamp/indicator column switch and its cunning twice-wrapped around the steering-column return spring.
Removal - Step One
Removal - Step Two
