I bought this 85 graduate as a known project. I was told it has a few cold starting problems and will only start with starter fluid until it has been running a few minutes. I have had it out driving a little (I want to go through some other parts of the engine before I drive it too much) and it usually does require starting fluid to start. Once I start it on the juice I need to keep giving it a little gas for the first 3 minutes or so until the engine warms up so it can idle on its own. I was thinking of replacing the Cold Start Valve and TTS both with items I can pick up off eBay, but was wondering if that is a likely cause, and if there is any way to test them before I drop $200+ on ebay or $400+ on pages like Vicks. Once I get the cold start figured out, I can move onto getting this beauty on the road more and the other issues it has. Thank you all for your help!!!!
The CSV and TTS help with starting but are inactive once the car starts. So your issue where it won't cold idle points to some other problem.
I would suggest going through the whole L-Jetronic guide here. It tells you how to test those parts but you likely have something else going on.
