Ok the 164 L that I just bought has a miss. I read the codes and I get a 1223. It backfires through the intake and runs rough. It did use a lot of fuel on the 60+ mile trip home. Seams like maybe 2 cylinders are missing?
I changed the Ebay K&N cone filter plate thing. Also put a good AFM and stock filter box back in the car no luck there. I did a compression test and about 210 in each cylinder. Checked for air leaks. Plugs (Lodge) wires cap and rotor are new as well as the cat and 02.
I am thinking injector(s) are bad/clogged.
