1 - 1 of 1 Posts
Can anyone give me the following "spring type" clutch specifications :
1 Height of clutch pressure plate mounting surface to surface where it
contacts disc .
2 Deflection distance needed to release disc .
3 Pressure [in ft. lbs.] that clutch should have at this distance ?
4 Installed clamping pressure ?
We are rebuilding type 121 engine for our S.S.
Engine was set up with non-standard lightweight [ steel & alum.] flywheel
that we do-not want to use.
Laurie Fraser
Langley B.C.
Canada
1 - 1 of 1 Posts
