1 - 20 of 163 Posts
I've been trying to track down why my reverse gear and second grind intermittently grind despite being a freshly rebuilt gear box and determined the reason to be that the clutch isn't fully disengaging. Now I've adjusted the master cylinder for no play in the peddle, changed the clevis pin, and ended up finding that with the clutch engaged (not pressing on the peddle), the clutch slave wiggles and has some play in it. This is a new slave from centerline. This leads to the pushrod misaligning and pushing on the fork at an angle which in turn doesn't disengage the clutch fully.
Has anyone seen this before? Is there a way I can space it out? Thanks!
from all the ones i have done.. there can be ' some ' wiggle.. if we found it..i installed a little thicker C clip on one side.. the easy side
weld...just kidding... its easy to over look something like this... my answer hours are closed now..must go to bed now, before my cat gets the best spot
Discussion Starter · #9 ·
So I ended up making a little shim and putting it behind the circlip and sure enough it got rid of the wiggle and works great! That being said it's still not fully disengaging so I think I'll have to pull the tranny :mad:to check out what is going on. I'm getting full travel at the slave it just seems like the arm on the slave is slightly to short which I know is not the case...
There is still a good bit of play in the fork so maybe one of the retaining clips fell out without me noticing or I somehow installed the clutch wrong. I'll have to dig in to find out.
1684855
Before you rip open the clutch, verify your clutch master rod length is set to spec. Also make sure your clutch pedal pivot hasn't failed: grab the clutch pedal and try to pull it towards you. If it moves up then the pivot is no bueno.
1684860
Discussion Starter · #12 ·
I have it set to spec and even a little longer to try to increase travel but still nothing. The pivot looks ok, a local alfa guy who knows much more than me also took a look at it and thinks the same.
There is a last bit of play in the clevis pin. I'm going to try replacing that before pulling the tranny in a last ditch effort.
the clevis pin can wear out as well getting a deep grove in it. also the clevis itself the hole, will become oval....i/we always replace the clevis an clevis pin drring repair the pedal get the most work after the gas pedal... lots and lots of shifting
Hey, maybe too late but how did you bleed your clutch? I just did mine and couldn’t get anywhere near the pedal I wanted until I moved the slave cylinder in while bleeding several times. Even with the motive power bleeder I had air in that slave. I read on the BB to push the slave in, and after doing that five/six times, being careful not to run out of fluid + motive power bleeder, my pedal is FIRM.
big vise grips to hold the bleed screw on the top.. then install a 35 inch long clear vinel hose on the bleeder..// route the hose up thru the engine bay, then into a small water bottle 1/3 filled with brake fuild to keep the end of the hose into... then pump pedal slowly till all bubbles in the hose are gone... keep the hose for later use( you will need it later ) then a tall glass or choc. milk,.
1 - 20 of 163 Posts
