Trying to get the rubber hose disconnected so I can finish pulling the slave out to rebuild it. Ran into a snag. On one side of the bracket is the hard line, with a retainer nut (?) on the bracket side. I got the retainer nut loose but, when tying to turn the nut on the hard line, it just twists the line, so I stopped. On the other side of the bracket is the rubber line. The bracket has that stupid 90 degree bend in the top so, I can't get a wrench on it to turn it. How do I get this thing off????? HELP! :frown2:
Your supposed to loosen the hard line first. Tighten it back up and loosen that first. I would PB-Blast it, and wire brush it 1st let it sit over night and it should come right out. That Guibo looks like it close to it's end as well.
Vise grips on the metal shank of the hose will hold it will you loosen the line nut.
