74 Spyder
For clarification purposes; my clutch slave cylinder was replaced about 2 years ago and works fine. I am in the process of a few projects including cleaning up some surface rust on the cross member. I have removed the line from master to the rubber hose so I can clean and treat that area without the line in the way.
I am not sure if the shop replaced the rubber hose so I figured I would do that as well. Before disconnecting the hose I noticed that the bleed nipple was at the 6 o'clock position (pointing straight down). I know from reading all the threads that the nipple should be straight up at 12 o'clock. Is it possible that the sc could rotate after being installed? Thanks.
