I'm trying to replace a failed clutch pivot arm. I followed the detailed instructions found on the BB and everything was going fine until I tried to remove the tapered pin that attaches the clutch pedal to the pivot arm shaft. After soaking it with penetrating oil and hammering the end of the tapered pin with a nail countersinking punch it still won't budge. I've read where other people have had the same problem but I haven't found a post that offers a solution.
I reinstalled the pivot arm housing to the fire wall and pulled up on the clutch pedal (it is now even with the brake pedal) hoping that this might eliminate any binding between the shaft and tapered pin but it still wouldn't budge when I retried hitting it with the punch.
I don't want to remove the entire assembly (disconnect the brake lines) to work on it on a bench if I really don't have to. Any help would be appreciated.
