1 - 13 of 13 Posts
After working flawlessly since bought, the clutch pedal suddenly got sinking under pressure and stays down, unless lifted, and stays up only under hinge spring. Ran perfect when driven last, about two weeks ago.
Didn't try to check if the the clutch engages or not, not to damage the transmission.
I was advised by my mechanic that the slave cylinder is the most likely culprit. One was ordered and will arrive in some weeks (the part is difficult to source in Israel...).
Since I didn't run a proper diagnostics, are there other "usual suspects", without going into exotics? The hydraulic fluid reservoir is full. Is there a sense to order the master cylinder as well, or it is common to be fixed by slave cylinder replacement?
Thanks in advance
Well, if it's not the slave then it's probably the master.
Any leaks under the car at the slave? That would be a pretty obvious hint. Also look under the dashboard at the rear end of the master cylinder: those can leak, and when they do they make a real mess on the inside of the firewall.
Just went through this with mine - if you are not leaking fluid near the trans (or any of the lines), then it is the master. Mine was bypassing the fluid past the piston, but not leaking into the car. Basically it would just recirculate the fluid to the reservoir. Neither slave or master are very expensive. All the $$$ will go to labor, especially for the master.
Discussion Starter · #5 ·
Thanks to every body.
There is no drip or pool of fluid under the car or in the car.
Because I can't safely raise the car and get underneath I have a problem bleeding the system and probably will wait for the slave cylinder to arrive and will tow it to the mechanic....
Apparently I should have bought the master with the slave and saved the shipment...
I will buy the master as well - to be on the safe side. Although those parts are more available than others for our cars, they are sort of perishable and better to have the spares at the shed :), or have the system new from end to end altogether....
Hmmm. I recently replaced my master and slave cylinders on recommendation from my mechanic. After replacing them though my clutch pedal doesn't come all the way back up. I have to pull it a little bit with my foot. Would that mean I potentially installed something incorrectly? What should I be checking for?
Mine would sink to the floor when I held the clutch in for a time (at a stop light) and then need to be pulled off the floor. When it got really bad, i woudl just need to touch the pedal and it woudl start sinking to the floor.
Sounds a bit different from your condition Phantom. there is some adjustment in the system and I wonder if that may be what you are experiencing. If it truely is a functional problem, you mechanic should set it right.
Moderator
We had this trouble with our 164LS, different car, but sounds like the same problem.
It was particles getting stuck under the seal in the slave, and when it was flushed problem went away, but I changed everything, slave, hose, master, just to get rid of all the crud from evidently a disintegrating hose, particles getting stuck everywhere.
The hoses Alfa used in the later cars, if not all, tended to fall apart internally, sending pieces throughout the system. Same for brake lines.
Discussion Starter · #10 ·
So, a brief update.
Bought master and slave cylinders.
Indeed, replacing the master cylinder is a source of constant swearing by the mechanic.
Eventually replaced only the slave cylinder and got my clutch back (the cylinder was drenched in fluid...)
The master cylinder will wait for the next failure.
Thanks for all the replies. Next - the A/C, that is barely effective, and the right front electric window.
Thanks in advance
Mine is a 115, it was stiff on the downward position tried to bring it up and broke the arm that is behind the brake booster, I took the clutch master cylinder out, and also the brake master cylinder and noted that this pivoting master clutch arm has a factory defect, the weld is not properly worked all the way around, inspected it and ordered a new one from Centerline, also the clutch cylinder was defective and frozen from sitting more than 6 months.
So there I will keep you updated with the installation of the new pin and pivoting arm,
It is not an easy task.
‘88 Milano, e30 s52 swap, 190e 16v, ................
if sitting 6 months compromised the clutch components 6 years plus would have melted the clutch parts completely.
my pedal is mad at me as well.
and it's leaking trans fluid, I'm guessing it's from the power steering.
1986 Alfa 75 2.0 twin carburetors
Had a similar clutch problem, but for me it was the rubber hose that connects to the slave. Looked good on the outside but aparently flakes of rubber got loose on the inside and the hose was acting like a one way valve. If you get down there I would also replace the hose just to be safe.
1 - 13 of 13 Posts
