Hello Alfisti. I went to take my spider out for a drive and my clutch pedal was very stiff and would not return. I had to pull it up with my hand and it was very hard! New slave. Replaced flex line. Is it the master?
Or the shaft in the pedal box that the clutch pedal pivots on. Try removing the clevis pin and seeing how freely the pedal & shaft move.I would remove the clevis pin and see if the pedal moves freely.
I agree. It's not even in line....something looks not right from the photo at least...From ur pic it looks like the clut cv h shaft is broken, hope not though
Yes, your next step is to remove the pedal box. It seems clear that the shaft the clutch pedal pivots on is sheared - certainly on the inboard side of the pedal. But I wonder what's going on with the shaft on the outboard side of the pedal. The pedal & shaft look offset forward from their original position. So the bushing in the box where the clutch shaft rides may be quite worn.Clovis pin put. Still still as hell! Should I pull the pedal box?
While you should have the torsion spring shown in spiderserie4's second picture, the lack of that spring is the least of your problems. My GT doesn't have the spring and it makes no difference; the compression spring in the MC returns the pedal with no difficulty. To my knowledge, replacement torsion springs are not available.Is there a spring that’s supposed to be there?
