I started what I thought would be a routine job. The cursing started shortly afterward. Someone along the ownership line had put the pin that holds the master cylinder to the clutch pedal in backwards. I couldn't get the carter pin out to remove the pin. I was able to saw off the arm from the master cylinder and take out the clutch pedal.
My cursing stopped and I began thanking that person because of what I found. The clutch pedal is cracked over half way and the hole for the pin is wallowed out. Fortunately I have a spare clutch pedal. Boy, am I glad i didn't through that out!!
