All,
I am starting to rebuild the clutch master cylinder. I have removed the master cylinder, got it taken apart, got all the gaskets replaced the same as they were when I removed the piston. I cannot get the piston to go back in as the new fresh gasket is slightly bigger due to no wear and tear and it also has a slight flare to it. The old gasket had the same flare. I cannot get the piston back into the master cylinder body due to this flare. Does anyone have a tip or some info that might help me......
