I've been getting some bad sounds from my clutch lately and I finally got the chance to drop the transmission and evaluate. My current setup consists of a lightened original flywheel, Sachs PP, and Spruell serrated Kevlar disc. I have a fairly hot 2L with close to 200HP.
Once got it all apart I was expecting to find a disintegrated throw out bearing but it was actually fine. What I found was a couple rivets broken on my Sachs pressure plate and shiny spots all over the friction surfaces. Spruell, had issued a tech bulletin saying they had a run of bad clutch discs, but upon inspection my disc seems ok. It is 0.361 thick (they are 0.375 new). I am thinking that improper setting of my clutch stop could have probably caused this if I was over-extending my pressure plates on a regular basis.
Either way I have a beautiful aluminum flywheel laying around that I've been wanting to install, I'm trying to figure out what the best pressure plate to run is, seems like Spruell offers 3 or 4 different ones (Sachs, upgraded Sachs, 911S type, etc). They also offer upgraded throwout bearings. I use my car for track days and hard street driving, but not full racing so I will stay with a sprung clutch disc but perhaps avoid the kevlar ones.
Any input appreciated.
Pictures:
[/url]image by vespam5, on Flickr[/IMG]
Richard Jemison
Clutch disk
You should have checked the friction co-efficient for clutch materials before you bought Kevlar (or Carbon fiber). Sintered metalic is too heavy. Stick with high temp organic lining!
I've had good luck with Kevlar clutch discs in the past (BMW M3), but this car didn't like it. I will definitely go with an organic compound this time around.
Thanks fellas.
