1969 GTV1750; 1973 GTV2000; 1974 Spider; 1986 Spider
The clutch actuating levers (the one the slave cylinder pushes to disengage the clutch) on my 1969 and 1973 Alfa GTVs both have a hole at the end. Is there supposed to be a spring attached to the lever? If so, what are the specifications of the spring and to what does the other end attach?
On my '74 under the stamped fork is a flat spring wire which you can see here. no conventional coil spring that I found. Ken
No spring on the outer end!
Right! Earlier design slave cylinders needed a spring on the T-O fork - hence the hole. When the hydraulics were re-designed, the hole was never removed from the T-O fork. So you can ignore it.
