21 - 23 of 23 Posts
No about the same and uses same gauge pressure transmitter but located in head on 24v.
Discussion Starter #22 (Edited)
Really? I’ve gone through many threads and many 24V engines have idle pressure above 15psi. But guess they’re less worn then.
I’m getting an oil pressure of 7-11psi.
Also off topic: what’s the difference between clutch slave cylinders 60511528 and 60801577? My compatibility research is getting very mixed results.
One is 23mm piston and one 25mm piston. Both work fine.
60511528 CLUTCH CYLINDER V1 01 164 23mm
60801577 CLUTCH CYLINDER V2 01 25mm 164S Bosch 0 260 005 580 25.4mm
21 - 23 of 23 Posts
