1 - 20 of 26 Posts
The clock in my '87 Spider has died. Anyone have a good working one for sale or know where to get one?
Is it the green or red display ?
Did you check for power @ the clock?
Thanks for responding and my apologies for not elaborating on the problem. The screen is no longer readable due to a dark "curtain" sliding down over the numbers. Sound familiar?
Spyder clock
I replaced the digital clock in my 86 with an analog Alfa clock. Works better, looks better, nd ain't going to crap-out.
sounds like the LCD Borg clock...i replaced mine with a green LED Borg...I think i can source you another but need to know if you need green LED or red LED
Follow-up: the display is black on white.
There are different Green BORG clocks. They don't have a "curtain" that goes over the display. They do have a glass or hard plastic lens, haven't tried to remove the lens on mine so can't say for certain if its glass or plastic.
It sounds like the clock you have, may have burned out its light bulb. Take a look at the back and see if you can pull out the bulb.
The other type of clock does not have a bulb. The display lights up on its own.
Here's a link to the type of BORG with both the bulb and without (LCD and LED).
http://www.alfabb.com/bb/forums/spider-1966-up/67123-light-bulb-digital-clock.html#post940039
....and there I go typing too slow again...
The correct clock for an '87 in an LCD black on green, no buttons like the '86 3 buttoner. If it fails, it's dead. The '86+ are interchangeable though, so choose the one you want and use it from whatever year you like and use it. *None of them require a bulb to be readable during the day- it's just for night illumination.
Because you have an early build car and it included an early build '87('86) clock. The vast majority of '87s out there don't have the 3 button Borg
Most of the '87s I've come across have the 3 button, but like I posted in the other thread, I did say that they may have changed in late '87. Either way, they're interchangeable, as you said. So, could we say that the correct version for an '87 is both LED/LCD, no button and three button (since Guido probably grabbed whatever he had in the parts bin at the time)?
So it looks like there was a point, like many other years, that the earlier builds of a given year get's some prior year stuff. Kinda like the first '86s that had the foam rear spoiler, but monopod. The moral is just drive it.
I have a May build '86 with 3 buttons and a May build '87 with no buttons. I'd gladly trade them for analog clocks. My 8s read as 3s since they're half burnt out and I never can tell what time it is! :rolleyes:
LOL Yup! Just like some '87s came with the silver and black bumpers and some came with body color matching and black bumpers too.
I'd like an easy way to change the color from green to red, blue, or orange. Sticking a gel in the LED version won't do anything but change the shade of green to something bluer or darker green. I'm too much of a chicken to try and pop out the lens in my clock. Luckily, my numbers are still working, so I can tell what time it is when I do get around to setting the clock.
Yeah the LED version has a colored lens, so if you could find a piece of flat broken tail light, you might be able to finagle something, since the LEDs themselves are clear. My 3 buttoner works fine too. It's the LCD one that looks like Chinese arithmetic.
Someday, I may work up the nerve to pop out that lens. For some reason, I feel like its green glass and just can't don't want to take the chance of breaking it. Maybe if I acquire another, I'll do it.
1966-2013
The face of the LED clock comes off by going around the back edge of the face/cover lip with a jewelers screwdriver and releasing the little snap clip thingies. There's a seam back there you can see, and IIRC, it only locks on two opposite sides, not all four. In any event, it's just popped together.
From there you'll find the colored lense is a piece of plastic, not glass.
Try not to drop the buttons, or at least have something to catch them instead of the console hole or under the seat.
Yeah, have taken my clock apart a bunch of times. Easy enough to do. It may well be green plastic, that would be a pain to replace if broken also. Mine just didn't have that "plastic" feeling. Tapping on it even sounded more like glass than plastic.
I'll risk breaking and take apart a working $80-$300 sensor or other thing on the car, to see how it works or what's in it, but too chicken [email protected]#t to try and pop out a green lens that's probably less than a dollar. Go figure.
1 - 20 of 26 Posts
