Cleaning out the parts bins...... all good condition OEM used and some are new/unused.
1300/1600 rear block spacer with bolts $35.00 Sold
1600 front timing idler gear $30.00
1600 timing chain tensioner w/spring, wedge and bolt $40.00 Sold
1600 Falcos oil filter top bolt assy. $45.00
1300/1600 driver side hard engine mount base $20.00
1300/1600 early spring loaded shift lever (missing top ?) $40.00 Sold
Set 4 new in box NGK B6ES spark plug set $ 15.00
Set 4 new Reinz green valve seals $10.00
New Shankle 1300/1600 Autosprint 2 pc. remote filter and/or cooler kit $75.00
New in Box AE Borgo 1600 liner (pink) with seal OEM $65.00
Set 4 aluminum 7mm wheel spacers (108mm) $25.00 Sold
Vintage AR leather / cloisonne shift knob (threaded) $65.00
6 chrome lug nuts 12x1.5 $10.00
S2 radio antenna with mounting hdwr (black top) $10.00 Sold
S2 10 position fuse block (no cover) $20.00
Freight is extra. USPS flat rate boxes are probably best/cheapest currently to lower 48 only.
PayPal F&F is easiest, checks are OK too. Sorry about the pics....
Sent me a PM or direct at usgi45s(at)hotmaildotcom for questions.
Thank you,
Bob
