1 - 1 of 1 Posts
Two little things:
If a a fuse blows and continues to blow when you replace it, put a 12 lamp across the empty fuse contacts. Then, if that circuit is shorted, the lamp will light with no damage. Keep looking at the lamp and poke around and when you find the short, the lamp will go out and you can fix the short and replace the lamp with a proper fuse.
Second, you can replace the mirror lamp with an LED from Ebay; picture shown. Gottaa cut the switch hole a bit depending on what you use.
Mike
1 - 1 of 1 Posts
