AR164-80 Checking 164 temp control stepper motor
Moving this info from this post: http://www.alfabb.com/bb/forums/164...ming-belt-water-pump-change-2.html#post474770
Now, new issue (sort of). I still have minimal heat in the ****pit. The steppers make no noise and everything seems to operate properly (shifting from floor to central to defrost, etc.). However, very little actual heat comes through. Any ideas on something simple to try? After spending around $2k plus the new tires ($400 for a set of snows) and exhaust ($300 for the 2 piece ANSA set) on my "new" car, I'd like to hold up on further expenses for a little while.
MarkZ
Stepper motors
First off there are two stepper motors. Front one is the one doing the control of air flow out of dash and that is one the front one you have working for certain since you can change air flow from dash to floor to defrost.
No you need to verify whether stepper for temp is working and if so is cable from it hooked to temp door lever in blower motor housing located below base of windshield and passenger side wiper arm pivot point.
Open hood, remove plastic cover over a/c components behind false firewall and with a flashlight locate cable and lever deep down in black hole between blower motor housing and evaporator box. Now with key on and somebody at temp control button on a/c panel raise temp to full hot and see if cable pulls lever back towards ****pit. Go to full cold and lever should push lever full forward towards engine.
Report you findings.
MarkZ
Stepper motors
