Good eveing all. An Alfa newbie here with some electrical issues. Car is a 1978 Spider Spica injected model. With the engine running the genrator light glows brighter as the engine speed increases. This is a 4 wire Bosch unit with a seperate regulator. Here's what I have done so far:
Replaced the voltage regulator.
Checked fuses at fuse block.
Cleaned fuse holders at fuse block.
Added ground strap from alternator to body.
Tried ground from alternator to battery.
Cleaned wire connectors at alternator and regulator.
Tried both full field tests on alternator and results suggest alternator is good.
After installing the new regulator the voltage will increase with engine speed up to about 12.7 volts from 12.0 at idle. Any info or help would be appreciated.
Brian
Brian
