I just noticed that the hose from the hose from the intake hard plastic middle section to the charcoal canister has a big gaping hole at the fender apron, which probably explains the idle issue I noticed after I changed my motor mounts last week. I'd like to fix it this weekend with locally sourced hoses from a BMW/Mercedes mechanic.
What size hose is this, and about how long is it?
Normally I'd just remove and measure the hose myself, but living in a commercial/residential condo development, I know that the dentist downstairs will have a hissy fit if he sees me working on the Spider in the parking lot!
Thanks!
Thanks!
For the S3....
10mm 4-5ft (10mm is hard to find, 3/8" fuel vapor hoseworks just fine (9.5mm))
Whilst you are in there change out the other smaller diameter hose that goes to the charcoal canister. I used 4-5ft of 4mm silicone hose for this.
Derek
Discussion Starter · #6 ·
Thanks for the info caliscouser!
Give the dentist a box of candy...
Ha! He'd probably appreciate it if I give his exiting patients toffee, taffy or rock candy!
Discussion Starter · #8 ·
Well I spent the day changing the charcoal canister hoses, along with installing a clean oil vapor separator and corresponding hoses. The old charcoal canister hoses basically crumbled in my hands as I was removing them. Fortunately there wasn't any rust or other corrosion in the charcoal canister or in the well where it's bolts.
After I was done, the car started with some coaxing, then it moved up to fast idle. After a minute or so, it idled around 1,100 to 1,200 RPM as shown on the car tach. I bought a new idle control "O" ring which I will install later and adjust the idle down slightly.
Thanks all for the input!
